48-472-122 FM issue
Try touching pin 1 of the 12au6 fm rf amp to hear if the signal increases. If not use a cap connected to pin 5 of the 12au6 and touch it. his should give you the same result as touching pin 8 of the 14F8. Also measure the voltage around the 12au6 is see if they are reasonable. Methinks your osc is ok too.
48-472-122 FM issue - by Eric Adams - 02-14-2019, 04:25 PM
RE: 48-472-122 FM issue - by PhilcoMike - 02-14-2019, 04:47 PM
RE: 48-472-122 FM issue - by Eric Adams - 02-14-2019, 04:54 PM
RE: 48-472-122 FM issue - by PhilcoMike - 02-15-2019, 04:50 PM
RE: 48-472-122 FM issue - by Radioroslyn - 02-15-2019, 08:18 PM
RE: 48-472-122 FM issue - by Eric Adams - 02-20-2019, 11:32 AM
RE: 48-472-122 FM issue - by EdHolland - 02-20-2019, 02:47 PM
91H Code 126 Restore
There are currently 4850 online users. [Complete List]
» 2 Member(s) | 4848 Guest(s)
