Gozinta
Does the Deoxit Fader Lube come in an aerosol can with a straw? I'm thinking simple, like maybe an adaptor to connect an aerosol straw to the control. Any thoughts?
We have pretty much hi-jacked this thread, maybe this discussion should be split off into it it's own.
M R Radios   C M Tubes
Gozinta - by Eliot Ness - 02-12-2019, 05:14 PM
RE: Gozinta - by Ron Ramirez - 02-15-2019, 10:57 PM
RE: Gozinta - by Ron Ramirez - 02-15-2019, 11:04 PM
RE: Gozinta - by 462ron - 02-15-2019, 11:48 PM
RE: Gozinta - by KCMike - 02-16-2019, 12:44 PM
RE: Gozinta - by EdHolland - 02-16-2019, 12:54 PM
RE: Gozinta - by morzh - 02-16-2019, 05:38 PM
RE: Gozinta - by 462ron - 02-16-2019, 10:36 PM
RE: Gozinta - by 462ron - 02-17-2019, 11:59 PM
RE: Gozinta - by morzh - 02-18-2019, 12:22 AM
RE: Gozinta - by 462ron - 02-18-2019, 10:53 AM
RE: Gozinta - by morzh - 02-18-2019, 11:51 AM
RE: Gozinta - by 462ron - 02-18-2019, 04:46 PM
RE: Gozinta - by morzh - 02-18-2019, 04:57 PM
RE: Gozinta - by EdHolland - 02-18-2019, 07:12 PM
RE: Gozinta - by 462ron - 02-18-2019, 07:24 PM
RE: Gozinta - by morzh - 02-22-2019, 07:19 PM
RE: Gozinta - by 462ron - 02-22-2019, 07:38 PM
RE: Gozinta - by morzh - 02-22-2019, 08:19 PM
RE: Gozinta - by 462ron - 02-22-2019, 09:14 PM
RE: Gozinta - by morzh - 02-22-2019, 10:08 PM
RE: Gozinta - by Eliot Ness - 02-23-2019, 11:14 PM
RE: Gozinta - by morzh - 02-23-2019, 11:36 PM
RE: Gozinta - by Eliot Ness - 05-06-2019, 02:51 PM
RE: Gozinta - by morzh - 05-06-2019, 03:06 PM
RE: Gozinta - by Phlogiston - 05-06-2019, 03:13 PM
RE: Gozinta - by morzh - 05-06-2019, 04:00 PM
RE: Zenith 5G500 - by morzh - 02-12-2019, 06:09 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-12-2019, 07:02 PM
RE: Zenith 5G500 - by David - 02-12-2019, 09:30 PM
RE: Zenith 5G500 - by Eliot Ness - 02-13-2019, 03:54 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-13-2019, 04:03 PM
RE: Zenith 5G500 - by EdHolland - 02-13-2019, 05:45 PM
RE: Zenith 5G500 - by morzh - 02-13-2019, 06:13 PM
RE: Zenith 5G500 - by Steve Davis - 02-13-2019, 09:17 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-13-2019, 10:42 PM
RE: Zenith 5G500 - by KCMike - 02-13-2019, 11:08 PM
RE: Zenith 5G500 - by KCMike - 02-14-2019, 01:40 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-14-2019, 01:45 PM
RE: Zenith 5G500 - by morzh - 02-14-2019, 02:37 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:07 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 01:09 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:09 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 01:12 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:17 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 01:21 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:25 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 05:38 PM
RE: Zenith 5G500 - by Steve Davis - 02-15-2019, 10:06 PM
RE: Zenith 5G500 - by Steve Davis - 02-15-2019, 10:07 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 10:21 PM
