42-395 decal
Hi Neewbie here
Im looking for the 42-395 decal thats in the center of the cab its abouyt 2" although I think I could make anything work.
Thanks
paparoach
42-395 decal - by paparoach - 11-03-2010, 05:59 PM
Re: 42-395 decal - by Ron Ramirez - 11-04-2010, 05:54 PM
There are currently 9535 online users. [Complete List]
» 2 Member(s) | 9533 Guest(s)
