Philco 76-1134 Antenna Coupler (three prong)
I know I'm late coming in on this but, are there any markings on the "coil" listed in the schematic?
Thanks Glenn
Happily back in Illinois..not.
Re: Philco 76-1134 Antenna Coupler (three prong) - by Glenn Roberts - 11-04-2010, 06:54 AM
Philco 91 Tuning Condenser
