Antenna wire
i use tractor supply electric fence wire which i think is either galv or tin coated.
I have all my small radios in one spot in the garage.
i come into the garage with the long wire into a 10postion rotary switch.
I rotate to the radio i want to listen to on my switch, power up and enjoy.
I use the old telephone pole glass or porcelain insulators to hold the wire.  I transition to insulated thhn #14awg when i pass through the garage wall and into my rotary switch.
here is a pic of my originally installed long wire.  I scaled it down to what seems to be about 200ft of bare wire.
its an interesting topic either way because i have often wondered myself this question i have...........
-what is the ideal wire type and wire gauge to use if you choose to use a long wire antenna only?
the second question i have asked lends better to knowing the answer before you build a long wire.....
-i was told a few times its better to get "out" and go "up" as high as you can with a long wire.
my future plan is to take that long horizontal run i have and swing that whole distance straight "UP".
i believe from what i am learning from others there is no net gain in going horizontal **unless** its a beverage antenna.
Antenna wire - by murf - 02-17-2019, 09:18 PM
RE: Antenna wire - by Paul Philco322 - 02-17-2019, 10:39 PM
RE: Antenna wire - by Ed Locker - 02-18-2019, 10:27 AM
RE: Antenna wire - by jcassity - 02-18-2019, 10:49 AM
RE: Antenna wire - by EdHolland - 02-18-2019, 02:13 PM
RE: Antenna wire - by murf - 02-18-2019, 05:01 PM
RE: Antenna wire - by EdHolland - 02-18-2019, 06:34 PM
RE: Antenna wire - by Ron Ramirez - 02-18-2019, 07:41 PM
RE: Antenna wire - by murf - 02-18-2019, 07:53 PM
RE: Antenna wire - by mikethedruid - 02-18-2019, 10:13 PM
RE: Antenna wire - by 462ron - 02-19-2019, 10:45 AM
RE: Antenna wire - by Ron Ramirez - 02-19-2019, 10:51 AM
RE: Antenna wire - by Paul Philco322 - 02-19-2019, 12:14 PM
RE: Antenna wire - by EdHolland - 02-19-2019, 02:57 PM
RE: Antenna wire - by murf - 02-19-2019, 04:16 PM
RE: Antenna wire - by murf - 02-19-2019, 04:19 PM
RE: Antenna wire - by murf - 02-19-2019, 04:22 PM
RE: Antenna wire - by murf - 02-19-2019, 04:41 PM
RE: Antenna wire - by Ron Ramirez - 02-19-2019, 04:47 PM
RE: Antenna wire - by EdHolland - 02-19-2019, 05:55 PM
RE: Antenna wire - by jcassity - 02-23-2019, 12:04 PM
RE: Antenna wire - by jcassity - 02-23-2019, 12:34 PM
RE: Antenna wire - by mikethedruid - 02-23-2019, 02:57 PM
RE: Antenna wire - by 462ron - 02-24-2019, 01:04 AM
RE: Antenna wire - by Stall-U-Rated - 02-24-2019, 02:37 AM
RE: Antenna wire - by jcassity - 02-24-2019, 11:45 AM
RE: Antenna wire - by EdHolland - 02-25-2019, 12:47 AM
RE: Antenna wire - by jcassity - 02-25-2019, 09:57 AM
RE: Antenna wire - by EdHolland - 02-25-2019, 09:14 PM
RE: Antenna wire - by Paul Philco322 - 02-25-2019, 09:23 PM
RE: Antenna wire - by jcassity - 02-26-2019, 01:14 PM
RE: Antenna wire - by EdHolland - 02-26-2019, 09:01 PM
RE: Antenna wire - by jcassity - 02-26-2019, 09:03 PM
RE: Antenna wire - by EdHolland - 02-27-2019, 08:29 PM
RE: Antenna wire - by murf - 03-09-2019, 09:04 PM
RE: Antenna wire - by Paul Philco322 - 03-09-2019, 09:18 PM
RE: Antenna wire - by tbone - 03-10-2019, 08:06 AM
RE: Antenna wire - by EdHolland - 03-10-2019, 05:54 PM
RE: Antenna wire - by tbone - 03-10-2019, 08:11 PM
RE: Antenna wire - by Paul Philco322 - 03-10-2019, 08:19 PM
RE: Antenna wire - by jcassity - 06-22-2019, 12:45 PM
RE: Antenna wire - by EdHolland - 06-27-2019, 12:08 PM
RE: Antenna wire - by PhilcoJohn - 06-29-2019, 06:43 AM
RE: Antenna wire - by jcassity - 07-14-2019, 11:09 AM
RE: Antenna wire - by EdHolland - 07-19-2019, 12:22 PM
RE: Antenna wire - by RodB - 09-19-2019, 08:04 PM
RE: Antenna wire - by Paul Philco322 - 09-19-2019, 09:09 PM
RE: Antenna wire - by EdHolland - 09-20-2019, 02:55 PM
RE: Antenna wire - by Phlogiston - 09-20-2019, 05:04 PM
RE: Antenna wire - by Simon Wa3uay - 09-20-2019, 07:07 PM
RE: Antenna wire - by EdHolland - 01-06-2020, 06:40 PM
RE: Antenna wire - by 2jackmans@gmail.com - 04-12-2022, 11:18 AM
RE: Antenna wire - by EdHolland - 04-13-2022, 09:04 PM
RE: Antenna wire - by 2jackmans@gmail.com - 04-13-2022, 11:55 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8761 online users. [Complete List]
» 3 Member(s) | 8758 Guest(s)
