Philco 16B Restoration
You should be looking at shorts in the rectifier tube's socket, namely from High voltage transformer output to the heater of the same tube.
Another possibility - a short between the High voltage and heater windings inside the transformer. Check with ohmmeter with power off.
PS. Somewhere there likely is a short. Before turning the radio on, with or without tubes, you should check for load/etc shorts first.
Philco 16B Restoration - by dkoczur - 01-23-2019, 03:13 PM
RE: Philco 16B Restoration - by radiodale - 01-23-2019, 03:44 PM
RE: Philco 16B Restoration - by dkoczur - 02-18-2019, 03:08 PM
RE: Philco 16B Restoration - by morzh - 02-18-2019, 03:18 PM
RE: Philco 16B Restoration - by dkoczur - 02-18-2019, 03:58 PM
91H Code 126 Restore
There are currently 3281 online users. [Complete List]
» 1 Member(s) | 3280 Guest(s)
