Gozinta
#38
I would be careful what it is gets exposed to. Even if the stuff for leaky transmissions works, you simply do not know how it reacts with the lubricant you are delivering inside the pot AND what it will do to the pot itself once it gets inside of it (it will).
Also, you might just soak it in the lubricant itself, it might just work. if using Deoxit Fader lube, soak the piston in it.
Gozinta - by Eliot Ness - 02-12-2019, 05:14 PM
RE: Gozinta - by Ron Ramirez - 02-15-2019, 10:57 PM
RE: Gozinta - by Ron Ramirez - 02-15-2019, 11:04 PM
RE: Gozinta - by 462ron - 02-15-2019, 11:48 PM
RE: Gozinta - by KCMike - 02-16-2019, 12:44 PM
RE: Gozinta - by EdHolland - 02-16-2019, 12:54 PM
RE: Gozinta - by morzh - 02-16-2019, 05:38 PM
RE: Gozinta - by 462ron - 02-16-2019, 10:36 PM
RE: Gozinta - by 462ron - 02-17-2019, 11:59 PM
RE: Gozinta - by morzh - 02-18-2019, 12:22 AM
RE: Gozinta - by 462ron - 02-18-2019, 10:53 AM
RE: Gozinta - by morzh - 02-18-2019, 11:51 AM
RE: Gozinta - by 462ron - 02-18-2019, 04:46 PM
RE: Gozinta - by morzh - 02-18-2019, 04:57 PM
RE: Gozinta - by EdHolland - 02-18-2019, 07:12 PM
RE: Gozinta - by 462ron - 02-18-2019, 07:24 PM
RE: Gozinta - by morzh - 02-22-2019, 07:19 PM
RE: Gozinta - by 462ron - 02-22-2019, 07:38 PM
RE: Gozinta - by morzh - 02-22-2019, 08:19 PM
RE: Gozinta - by 462ron - 02-22-2019, 09:14 PM
RE: Gozinta - by morzh - 02-22-2019, 10:08 PM
RE: Gozinta - by Eliot Ness - 02-23-2019, 11:14 PM
RE: Gozinta - by morzh - 02-23-2019, 11:36 PM
RE: Gozinta - by Eliot Ness - 05-06-2019, 02:51 PM
RE: Gozinta - by morzh - 05-06-2019, 03:06 PM
RE: Gozinta - by Phlogiston - 05-06-2019, 03:13 PM
RE: Gozinta - by morzh - 05-06-2019, 04:00 PM
RE: Zenith 5G500 - by morzh - 02-12-2019, 06:09 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-12-2019, 07:02 PM
RE: Zenith 5G500 - by David - 02-12-2019, 09:30 PM
RE: Zenith 5G500 - by Eliot Ness - 02-13-2019, 03:54 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-13-2019, 04:03 PM
RE: Zenith 5G500 - by EdHolland - 02-13-2019, 05:45 PM
RE: Zenith 5G500 - by morzh - 02-13-2019, 06:13 PM
RE: Zenith 5G500 - by Steve Davis - 02-13-2019, 09:17 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-13-2019, 10:42 PM
RE: Zenith 5G500 - by KCMike - 02-13-2019, 11:08 PM
RE: Zenith 5G500 - by KCMike - 02-14-2019, 01:40 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-14-2019, 01:45 PM
RE: Zenith 5G500 - by morzh - 02-14-2019, 02:37 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:07 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 01:09 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:09 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 01:12 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:17 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 01:21 PM
RE: Zenith 5G500 - by 462ron - 02-15-2019, 01:25 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 05:38 PM
RE: Zenith 5G500 - by Steve Davis - 02-15-2019, 10:06 PM
RE: Zenith 5G500 - by Steve Davis - 02-15-2019, 10:07 PM
RE: Zenith 5G500 - by morzh - 02-15-2019, 10:21 PM
Eico 232 VTVM Schematic
There are currently 9086 online users. [Complete List]
» 1 Member(s) | 9085 Guest(s)
