Philco 76-1134 Antenna Coupler (three prong)
I can't see any marks, but was able to emasure it - 0.292 mH
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Re: Philco 76-1134 Antenna Coupler (three prong) - by FStephenMasek - 11-05-2010, 12:54 AM
Philco 91 Tuning Condenser
