Zenith 5G500
Yesterday received the connector from Ed; I was wrong (I made the drawings and thought he mirrored the pins) and the connector fits like a glove. One pin does not make contact which means that my connector has to be disassembled again and the sockets pressed a bit.
Ed will make the rest of the battery so I will have pretty much one and only Z-675 made by him. Actually it was my idea; I said that as there are quite a few 5G500 and likes that use the same battery there might be people who would order those same as there are those who order 985 and 909 ones. So he might add it to the offering on his website.
Zenith 5G500 - by morzh - 01-26-2019, 09:18 PM
RE: Zenith 5G500 - by morzh - 01-27-2019, 09:10 PM
RE: Zenith 5G500 - by Eliot Ness - 01-28-2019, 10:33 AM
RE: Zenith 5G500 - by Phlogiston - 01-28-2019, 12:05 PM
RE: Zenith 5G500 - by morzh - 01-28-2019, 12:46 PM
RE: Zenith 5G500 - by Phlogiston - 01-28-2019, 02:45 PM
RE: Zenith 5G500 - by David - 01-28-2019, 02:58 PM
RE: Zenith 5G500 - by morzh - 01-28-2019, 05:53 PM
RE: Zenith 5G500 - by Phlogiston - 02-01-2019, 12:14 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 02:47 PM
RE: Zenith 5G500 - by Phlogiston - 02-01-2019, 03:33 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 06:14 PM
RE: Zenith 5G500 - by jcassity - 02-01-2019, 06:53 PM
RE: Zenith 5G500 - by Eliot Ness - 02-01-2019, 09:30 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 10:44 PM
RE: Zenith 5G500 - by Eliot Ness - 02-01-2019, 11:33 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 11:57 PM
RE: Zenith 5G500 - by morzh - 02-05-2019, 12:10 AM
RE: Zenith 5G500 - by morzh - 02-10-2019, 09:29 PM
RE: Zenith 5G500 - by David - 02-10-2019, 09:55 PM
RE: Zenith 5G500 - by morzh - 02-10-2019, 11:21 PM
RE: Zenith 5G500 - by EdHolland - 02-11-2019, 05:26 PM
RE: Zenith 5G500 - by morzh - 02-11-2019, 05:37 PM
RE: Zenith 5G500 - by David - 02-12-2019, 01:28 PM
RE: Zenith 5G500 - by morzh - 02-12-2019, 10:26 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 10:59 PM
RE: Zenith 5G500 - by morzh - 02-16-2019, 05:20 PM
RE: Zenith 5G500 - by morzh - 02-17-2019, 03:26 PM
RE: Zenith 5G500 - by Arran - 02-17-2019, 10:40 PM
RE: Zenith 5G500 - by morzh - 02-20-2019, 10:07 AM
RE: Zenith 5G500 - by WyTex - 02-20-2019, 10:48 AM
RE: Zenith 5G500 - by morzh - 02-20-2019, 01:11 PM
RE: Zenith 5G500 - by morzh - 02-23-2019, 01:39 PM
RE: Zenith 5G500 - by Eliot Ness - 02-24-2019, 12:56 PM
RE: Zenith 5G500 - by morzh - 02-24-2019, 10:22 PM
RE: Zenith 5G500 - by morzh - 02-25-2019, 10:22 PM
RE: Zenith 5G500 - by Arran - 02-26-2019, 02:58 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 08:47 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 08:52 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 10:10 AM
RE: Zenith 5G500 - by morzh - 02-27-2019, 08:40 AM
RE: Zenith 5G500 - by WyTex - 02-27-2019, 09:53 AM
RE: Zenith 5G500 - by Eliot Ness - 02-27-2019, 09:59 AM
RE: Zenith 5G500 - by morzh - 02-27-2019, 12:26 PM
RE: Zenith 5G500 - by Eliot Ness - 02-27-2019, 04:29 PM
RE: Zenith 5G500 - by morzh - 02-27-2019, 09:29 PM
RE: Zenith 5G500 - by morzh - 02-27-2019, 09:44 PM
RE: Zenith 5G500 - by Eliot Ness - 02-28-2019, 03:52 PM
RE: Zenith 5G500 - by morzh - 02-28-2019, 05:23 PM
RE: Zenith 5G500 - by Phlogiston - 03-01-2019, 12:36 PM
RE: Zenith 5G500 - by Phlogiston - 03-01-2019, 12:41 PM
RE: Zenith 5G500 - by morzh - 03-01-2019, 12:51 PM
RE: Zenith 5G500 - by Arran - 03-02-2019, 02:39 AM
RE: Zenith 5G500 - by morzh - 03-02-2019, 08:44 PM
RE: Zenith 5G500 - by morzh - 03-03-2019, 05:02 PM
RE: Zenith 5G500 - by Phlogiston - 03-03-2019, 08:35 PM
RE: Zenith 5G500 - by morzh - 03-04-2019, 09:38 AM
RE: Zenith 5G500 - by morzh - 03-04-2019, 10:08 PM
RE: Zenith 5G500 - by Eliot Ness - 03-05-2019, 11:16 AM
RE: Zenith 5G500 - by morzh - 03-05-2019, 02:13 PM
RE: Zenith 5G500 - by Eliot Ness - 03-05-2019, 02:39 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 06:47 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 08:09 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 09:56 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 09:57 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 08:43 AM
RE: Zenith 5G500 - by Eliot Ness - 03-06-2019, 03:27 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 04:12 PM
RE: Zenith 5G500 - by EdHolland - 03-06-2019, 05:01 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 11:45 PM
RE: Zenith 5G500 - by WyTex - 03-07-2019, 10:02 AM
RE: Zenith 5G500 - by morzh - 03-07-2019, 10:59 AM
RE: Zenith 5G500 - by WyTex - 03-07-2019, 01:57 PM
RE: Zenith 5G500 - by morzh - 03-07-2019, 02:28 PM
RE: Zenith 5G500 - by morzh - 03-07-2019, 02:30 PM
RE: Zenith 5G500 - by morzh - 03-09-2019, 12:03 PM
RE: Zenith 5G500 - by OldRestorer - 03-09-2019, 09:52 PM
RE: Zenith 5G500 - by morzh - 03-09-2019, 11:01 PM
Users browsing this thread: 14 Guest(s)
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 2031 online users. [Complete List]
» 3 Member(s) | 2028 Guest(s)
