48-472-122 FM issue
Hi Terry,
Here's what I got: Touching pin 1 of the 12AU6 did nothing. Touching a cap to pin five was as you stated-just like touching pin 8 of the 14F8. I measured the voltages at the 12AU6. The only ones that were correct were the filament voltages. The others were 0 or negative.
Any ideas were to look?
In the meantime I'm going to check more voltages.
Thanks for your help.
Eric
The Villages, FL
48-472-122 FM issue - by Eric Adams - 02-14-2019, 04:25 PM
RE: 48-472-122 FM issue - by PhilcoMike - 02-14-2019, 04:47 PM
RE: 48-472-122 FM issue - by Eric Adams - 02-14-2019, 04:54 PM
RE: 48-472-122 FM issue - by PhilcoMike - 02-15-2019, 04:50 PM
RE: 48-472-122 FM issue - by Radioroslyn - 02-15-2019, 08:18 PM
RE: 48-472-122 FM issue - by Eric Adams - 02-20-2019, 11:32 AM
RE: 48-472-122 FM issue - by EdHolland - 02-20-2019, 02:47 PM
91H Code 126 Restore
There are currently 4080 online users. [Complete List]
» 3 Member(s) | 4077 Guest(s)
