Antenna wire
here is a drawing of my original 5 position rotary switch which i changed to a 10 a few weeks ago.
one thing i learned about radios with "loop" antennas.  I asked here how can i integrate a loop antenna radio to a long wire to get better reception.  i tinkered a little bit and i learned that if you simply solder a 2 or 3 foot long wire out the back which is soldered to one side of the loop antenna , you nearly double its ability to pick up stations.
This is a matter of trial and error but it worked two times for me ,, on a small GE and on a Zenith, both with loop antennas.
 if this short hanging piece of wire is moved around or adjusted it helps the signal as well.  In my case i noticed that if turn on my GE and rotate my rotary switch to pos 2, somehow the GE couples with the early 90's era magnavox for the best reception.  i still have no clue why since the little GE is not even on the rotary switch.
Antenna wire - by murf - 02-17-2019, 09:18 PM
RE: Antenna wire - by Paul Philco322 - 02-17-2019, 10:39 PM
RE: Antenna wire - by Ed Locker - 02-18-2019, 10:27 AM
RE: Antenna wire - by jcassity - 02-18-2019, 10:49 AM
RE: Antenna wire - by EdHolland - 02-18-2019, 02:13 PM
RE: Antenna wire - by murf - 02-18-2019, 05:01 PM
RE: Antenna wire - by EdHolland - 02-18-2019, 06:34 PM
RE: Antenna wire - by Ron Ramirez - 02-18-2019, 07:41 PM
RE: Antenna wire - by murf - 02-18-2019, 07:53 PM
RE: Antenna wire - by mikethedruid - 02-18-2019, 10:13 PM
RE: Antenna wire - by 462ron - 02-19-2019, 10:45 AM
RE: Antenna wire - by Ron Ramirez - 02-19-2019, 10:51 AM
RE: Antenna wire - by Paul Philco322 - 02-19-2019, 12:14 PM
RE: Antenna wire - by EdHolland - 02-19-2019, 02:57 PM
RE: Antenna wire - by murf - 02-19-2019, 04:16 PM
RE: Antenna wire - by murf - 02-19-2019, 04:19 PM
RE: Antenna wire - by murf - 02-19-2019, 04:22 PM
RE: Antenna wire - by murf - 02-19-2019, 04:41 PM
RE: Antenna wire - by Ron Ramirez - 02-19-2019, 04:47 PM
RE: Antenna wire - by EdHolland - 02-19-2019, 05:55 PM
RE: Antenna wire - by jcassity - 02-23-2019, 12:04 PM
RE: Antenna wire - by jcassity - 02-23-2019, 12:34 PM
RE: Antenna wire - by mikethedruid - 02-23-2019, 02:57 PM
RE: Antenna wire - by 462ron - 02-24-2019, 01:04 AM
RE: Antenna wire - by Stall-U-Rated - 02-24-2019, 02:37 AM
RE: Antenna wire - by jcassity - 02-24-2019, 11:45 AM
RE: Antenna wire - by EdHolland - 02-25-2019, 12:47 AM
RE: Antenna wire - by jcassity - 02-25-2019, 09:57 AM
RE: Antenna wire - by EdHolland - 02-25-2019, 09:14 PM
RE: Antenna wire - by Paul Philco322 - 02-25-2019, 09:23 PM
RE: Antenna wire - by jcassity - 02-26-2019, 01:14 PM
RE: Antenna wire - by EdHolland - 02-26-2019, 09:01 PM
RE: Antenna wire - by jcassity - 02-26-2019, 09:03 PM
RE: Antenna wire - by EdHolland - 02-27-2019, 08:29 PM
RE: Antenna wire - by murf - 03-09-2019, 09:04 PM
RE: Antenna wire - by Paul Philco322 - 03-09-2019, 09:18 PM
RE: Antenna wire - by tbone - 03-10-2019, 08:06 AM
RE: Antenna wire - by EdHolland - 03-10-2019, 05:54 PM
RE: Antenna wire - by tbone - 03-10-2019, 08:11 PM
RE: Antenna wire - by Paul Philco322 - 03-10-2019, 08:19 PM
RE: Antenna wire - by jcassity - 06-22-2019, 12:45 PM
RE: Antenna wire - by EdHolland - 06-27-2019, 12:08 PM
RE: Antenna wire - by PhilcoJohn - 06-29-2019, 06:43 AM
RE: Antenna wire - by jcassity - 07-14-2019, 11:09 AM
RE: Antenna wire - by EdHolland - 07-19-2019, 12:22 PM
RE: Antenna wire - by RodB - 09-19-2019, 08:04 PM
RE: Antenna wire - by Paul Philco322 - 09-19-2019, 09:09 PM
RE: Antenna wire - by EdHolland - 09-20-2019, 02:55 PM
RE: Antenna wire - by Phlogiston - 09-20-2019, 05:04 PM
RE: Antenna wire - by Simon Wa3uay - 09-20-2019, 07:07 PM
RE: Antenna wire - by EdHolland - 01-06-2020, 06:40 PM
RE: Antenna wire - by 2jackmans@gmail.com - 04-12-2022, 11:18 AM
RE: Antenna wire - by EdHolland - 04-13-2022, 09:04 PM
RE: Antenna wire - by 2jackmans@gmail.com - 04-13-2022, 11:55 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 7893 online users. [Complete List]
» 2 Member(s) | 7891 Guest(s)
