zenith 8D625 radio
Sounds like you got a great deal.
It might be a time bomb though, give some thought to replacing the electrolytic and coupling capacitors to keep the set going a few more decades.
zenith 8D625 radio - by philcoradio1234 - 11-07-2010, 02:30 PM
Re: zenith 8D625 radio - by codefox1 - 11-07-2010, 04:16 PM
Re: zenith 8D625 radio - by philcoradio1234 - 11-07-2010, 05:58 PM
Re: zenith 8D625 radio - by exray - 11-07-2010, 09:21 PM
Re: zenith 8D625 radio - by philcoradio1234 - 11-08-2010, 04:25 PM
Eico 232 VTVM Schematic
There are currently 9337 online users. [Complete List]
» 1 Member(s) | 9336 Guest(s)
