zenith 8D625 radio
I've never heard of an 8D625. Must be rare Icon_smile There's a 5D625 that looks like the one in the photo and is very common but it doesn't have 40 caps!
Here's the schematic for the 5D625. (Hint - the first digit in that era of Zenith model numbers indicates the tube count)
<!-- m --><a class="postlink" href="http://www.nostalgiaair.org/PagesByModel/926/M0024926.pdf">http://www.nostalgiaair.org/PagesByMode ... 024926.pdf</a><!-- m -->
$10 was a good deal.
I'll parrot the advice about recapping.
zenith 8D625 radio - by philcoradio1234 - 11-07-2010, 02:30 PM
Re: zenith 8D625 radio - by codefox1 - 11-07-2010, 04:16 PM
Re: zenith 8D625 radio - by philcoradio1234 - 11-07-2010, 05:58 PM
Re: zenith 8D625 radio - by exray - 11-07-2010, 09:21 PM
Re: zenith 8D625 radio - by philcoradio1234 - 11-08-2010, 04:25 PM
There are currently 3780 online users. [Complete List]
» 1 Member(s) | 3779 Guest(s)
