CABINET TOP REFINISHING QUESTION
Thanks for your reply, Bob.  This radio is a floor model.  I have successfully removed the small spot of urethane which I applied and am now ready to try either toner or stain.  As it is almost impossible to obtain toner in Canada I will go with the stain followed by sprayed on Watco satin lacquer ( a couple of local wood finishers recommended satin lacquer over semi-gloss).  Knowing that the wood is quite possibly walnut helps but it is not veneer but solid 3/4" wood.  I will try to locate a piece of walnut on which to experiment. I tried unsuccessfully to attach three pix of the radio.
Bill
CABINET TOP REFINISHING QUESTION - by willy41 - 03-02-2019, 09:21 AM
RE: CABINET TOP REFINISHING QUESTION - by willy41 - 03-02-2019, 11:21 PM
RE: CABINET TOP REFINISHING QUESTION - by Arran - 03-04-2019, 06:39 AM
RE: CABINET TOP REFINISHING QUESTION - by Patrick - 03-04-2019, 07:54 AM
RE: CABINET TOP REFINISHING QUESTION - by willy41 - 03-04-2019, 09:32 AM
RE: CABINET TOP REFINISHING QUESTION - by willy41 - 03-23-2019, 08:53 PM
RE: CABINET TOP REFINISHING QUESTION - by willy41 - 03-23-2019, 08:54 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 6475 online users. [Complete List]
» 2 Member(s) | 6473 Guest(s)
