Hallicrafters Model S-107
its apparently not a bad set.. but am no expert.
i hare restored a half dozen hallicrafters from s38 to s53.
lookie there
http://wd4eui.com/Hallicrafters_S_107.html
the shorting is disabled if you use a long wire to terminal 1.
,, not sure on the rubber grommet.
i actually can appreciate how it extracts out the front instead of the rear.
Hallicrafters Model S-107 - by Greggshere - 03-03-2019, 02:34 PM
RE: Hallicrafters Model S-107 - by jcassity - 03-03-2019, 03:37 PM
RE: Hallicrafters Model S-107 - by David - 03-03-2019, 07:33 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2539 online users. [Complete List]
» 3 Member(s) | 2536 Guest(s)
