Zenith 5G500
#72
The rivets seem to be made of a fairly good material, not sure brass or steel, but it could be un-bent and then bent back without showing signs of breakage.
I used the awl I showed in the previous page on a picture.
I did not puncture too deep, to not damage wood too much, and then tried to pull the curl out. To maximize the leverage I use a flat piece of metal as a fulcrum, close to the rivet's curl, to support the awl, else the angle is not enough to apply any effort.
Once the curl is out, i straighten it with pliers, then do the same to the second curl, then simply pull the rivet.
To curl it back when re-inserting the rivets, I use sturdy but narrow-tip needle-nose pliers. The nose needs to be thin at the end but widening fast so not to bend when curling.
Zenith 5G500 - by morzh - 01-26-2019, 09:18 PM
RE: Zenith 5G500 - by morzh - 01-27-2019, 09:10 PM
RE: Zenith 5G500 - by Eliot Ness - 01-28-2019, 10:33 AM
RE: Zenith 5G500 - by Phlogiston - 01-28-2019, 12:05 PM
RE: Zenith 5G500 - by morzh - 01-28-2019, 12:46 PM
RE: Zenith 5G500 - by Phlogiston - 01-28-2019, 02:45 PM
RE: Zenith 5G500 - by David - 01-28-2019, 02:58 PM
RE: Zenith 5G500 - by morzh - 01-28-2019, 05:53 PM
RE: Zenith 5G500 - by Phlogiston - 02-01-2019, 12:14 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 02:47 PM
RE: Zenith 5G500 - by Phlogiston - 02-01-2019, 03:33 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 06:14 PM
RE: Zenith 5G500 - by jcassity - 02-01-2019, 06:53 PM
RE: Zenith 5G500 - by Eliot Ness - 02-01-2019, 09:30 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 10:44 PM
RE: Zenith 5G500 - by Eliot Ness - 02-01-2019, 11:33 PM
RE: Zenith 5G500 - by morzh - 02-01-2019, 11:57 PM
RE: Zenith 5G500 - by morzh - 02-05-2019, 12:10 AM
RE: Zenith 5G500 - by morzh - 02-10-2019, 09:29 PM
RE: Zenith 5G500 - by David - 02-10-2019, 09:55 PM
RE: Zenith 5G500 - by morzh - 02-10-2019, 11:21 PM
RE: Zenith 5G500 - by EdHolland - 02-11-2019, 05:26 PM
RE: Zenith 5G500 - by morzh - 02-11-2019, 05:37 PM
RE: Zenith 5G500 - by David - 02-12-2019, 01:28 PM
RE: Zenith 5G500 - by morzh - 02-12-2019, 10:26 PM
RE: Zenith 5G500 - by Ron Ramirez - 02-15-2019, 10:59 PM
RE: Zenith 5G500 - by morzh - 02-16-2019, 05:20 PM
RE: Zenith 5G500 - by morzh - 02-17-2019, 03:26 PM
RE: Zenith 5G500 - by Arran - 02-17-2019, 10:40 PM
RE: Zenith 5G500 - by morzh - 02-20-2019, 10:07 AM
RE: Zenith 5G500 - by WyTex - 02-20-2019, 10:48 AM
RE: Zenith 5G500 - by morzh - 02-20-2019, 01:11 PM
RE: Zenith 5G500 - by morzh - 02-23-2019, 01:39 PM
RE: Zenith 5G500 - by Eliot Ness - 02-24-2019, 12:56 PM
RE: Zenith 5G500 - by morzh - 02-24-2019, 10:22 PM
RE: Zenith 5G500 - by morzh - 02-25-2019, 10:22 PM
RE: Zenith 5G500 - by Arran - 02-26-2019, 02:58 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 08:47 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 08:52 AM
RE: Zenith 5G500 - by morzh - 02-26-2019, 10:10 AM
RE: Zenith 5G500 - by morzh - 02-27-2019, 08:40 AM
RE: Zenith 5G500 - by WyTex - 02-27-2019, 09:53 AM
RE: Zenith 5G500 - by Eliot Ness - 02-27-2019, 09:59 AM
RE: Zenith 5G500 - by morzh - 02-27-2019, 12:26 PM
RE: Zenith 5G500 - by Eliot Ness - 02-27-2019, 04:29 PM
RE: Zenith 5G500 - by morzh - 02-27-2019, 09:29 PM
RE: Zenith 5G500 - by morzh - 02-27-2019, 09:44 PM
RE: Zenith 5G500 - by Eliot Ness - 02-28-2019, 03:52 PM
RE: Zenith 5G500 - by morzh - 02-28-2019, 05:23 PM
RE: Zenith 5G500 - by Phlogiston - 03-01-2019, 12:36 PM
RE: Zenith 5G500 - by Phlogiston - 03-01-2019, 12:41 PM
RE: Zenith 5G500 - by morzh - 03-01-2019, 12:51 PM
RE: Zenith 5G500 - by Arran - 03-02-2019, 02:39 AM
RE: Zenith 5G500 - by morzh - 03-02-2019, 08:44 PM
RE: Zenith 5G500 - by morzh - 03-03-2019, 05:02 PM
RE: Zenith 5G500 - by Phlogiston - 03-03-2019, 08:35 PM
RE: Zenith 5G500 - by morzh - 03-04-2019, 09:38 AM
RE: Zenith 5G500 - by morzh - 03-04-2019, 10:08 PM
RE: Zenith 5G500 - by Eliot Ness - 03-05-2019, 11:16 AM
RE: Zenith 5G500 - by morzh - 03-05-2019, 02:13 PM
RE: Zenith 5G500 - by Eliot Ness - 03-05-2019, 02:39 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 06:47 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 08:09 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 09:56 PM
RE: Zenith 5G500 - by morzh - 03-05-2019, 09:57 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 08:43 AM
RE: Zenith 5G500 - by Eliot Ness - 03-06-2019, 03:27 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 04:12 PM
RE: Zenith 5G500 - by EdHolland - 03-06-2019, 05:01 PM
RE: Zenith 5G500 - by morzh - 03-06-2019, 11:45 PM
RE: Zenith 5G500 - by WyTex - 03-07-2019, 10:02 AM
RE: Zenith 5G500 - by morzh - 03-07-2019, 10:59 AM
RE: Zenith 5G500 - by WyTex - 03-07-2019, 01:57 PM
RE: Zenith 5G500 - by morzh - 03-07-2019, 02:28 PM
RE: Zenith 5G500 - by morzh - 03-07-2019, 02:30 PM
RE: Zenith 5G500 - by morzh - 03-09-2019, 12:03 PM
RE: Zenith 5G500 - by OldRestorer - 03-09-2019, 09:52 PM
RE: Zenith 5G500 - by morzh - 03-09-2019, 11:01 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
There are currently 1711 online users. [Complete List]
» 3 Member(s) | 1708 Guest(s)
