Stall's 16b cathedral
#98
You can use conductive tools on both BUT there are a few issues.
Using a metal nut driver on the trimmer caps is a little problematic. Some of the trimmers have HV present so the driver needs to be insulted so  it doesn't short against any metal object near the trimmer. And you don't want to find yourself between the chassis and the metal portion of the driver. A layer of tape works ok.
The weigh of the driver can depress the copper sheet on the trimmer and not give you a proper alignment. I'll notice when you remove the driver the alignment will shift.
On the screw adjustment same as the nuts in terms of the HV. The weigh doesn't come into play.
Stall's 16b cathedral - by Stall-U-Rated - 09-20-2017, 11:50 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 09-21-2017, 12:47 AM
RE: Stall's 16b cathedral - by morzh - 09-21-2017, 08:41 AM
RE: Stall's 16b cathedral - by bikenepa - 09-21-2017, 12:14 PM
RE: Stall's 16b cathedral - by morzh - 09-21-2017, 01:08 PM
RE: Stall's 16b cathedral - by bikenepa - 09-21-2017, 03:20 PM
RE: Stall's 16b cathedral - by morzh - 09-21-2017, 04:34 PM
RE: Stall's 16b cathedral - by bikenepa - 09-21-2017, 04:39 PM
RE: Stall's 16b cathedral - by morzh - 09-21-2017, 04:41 PM
RE: Stall's 16b cathedral - by KCMike - 09-21-2017, 05:18 PM
RE: Stall's 16b cathedral - by Chris h - 09-22-2017, 07:54 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 09-23-2017, 09:03 PM
RE: Stall's 16b cathedral - by morzh - 09-23-2017, 09:21 PM
RE: Stall's 16b cathedral - by Radioroslyn - 09-24-2017, 07:26 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 09-25-2017, 12:59 AM
RE: Stall's 16b cathedral - by morzh - 09-25-2017, 09:59 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 09-26-2017, 01:16 AM
RE: Stall's 16b cathedral - by morzh - 09-26-2017, 08:08 AM
RE: Stall's 16b cathedral - by Radioroslyn - 10-20-2017, 12:02 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 10-20-2017, 12:40 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 11-10-2017, 08:35 PM
RE: Stall's 16b cathedral - by morzh - 11-10-2017, 09:28 PM
RE: Stall's 16b cathedral - by Steve Davis - 11-10-2017, 11:56 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 11-27-2017, 12:05 AM
RE: Stall's 16b cathedral - by morzh - 11-28-2017, 11:40 PM
RE: Stall's 16b cathedral - by Radioroslyn - 11-29-2017, 09:15 AM
RE: Stall's 16b cathedral - by morzh - 11-29-2017, 10:33 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 11-30-2017, 02:05 AM
RE: Stall's 16b cathedral - by 462ron - 11-30-2017, 09:04 AM
RE: Stall's 16b cathedral - by morzh - 11-30-2017, 11:15 AM
RE: Stall's 16b cathedral - by 462ron - 11-30-2017, 08:12 PM
RE: Stall's 16b cathedral - by morzh - 12-01-2017, 12:10 AM
RE: Stall's 16b cathedral - by 462ron - 12-01-2017, 07:52 AM
RE: Stall's 16b cathedral - by Arran - 12-02-2017, 12:33 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-06-2018, 06:48 PM
RE: Stall's 16b cathedral - by morzh - 01-06-2018, 07:16 PM
RE: Stall's 16b cathedral - by morzh - 01-07-2018, 02:40 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-07-2018, 06:55 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-15-2018, 10:00 PM
RE: Stall's 16b cathedral - by morzh - 01-15-2018, 10:06 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 06-23-2018, 09:24 PM
RE: Stall's 16b cathedral - by morzh - 06-23-2018, 09:41 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 06-24-2018, 01:31 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 12-29-2018, 07:12 PM
RE: Stall's 16b cathedral - by morzh - 12-29-2018, 09:37 PM
RE: Stall's 16b cathedral - by Steve Davis - 12-29-2018, 09:55 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 12-30-2018, 12:40 AM
RE: Stall's 16b cathedral - by morzh - 12-30-2018, 12:47 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 12-30-2018, 03:17 AM
RE: Stall's 16b cathedral - by klondike98 - 12-30-2018, 11:49 AM
RE: Stall's 16b cathedral - by morzh - 12-30-2018, 03:09 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 12-30-2018, 07:39 PM
RE: Stall's 16b cathedral - by Steve Davis - 12-30-2018, 08:59 PM
RE: Stall's 16b cathedral - by klondike98 - 01-05-2019, 10:43 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-12-2019, 10:14 PM
RE: Stall's 16b cathedral - by Radioroslyn - 01-12-2019, 10:53 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-14-2019, 06:11 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-15-2019, 09:11 PM
RE: Stall's 16b cathedral - by EdHolland - 01-17-2019, 03:18 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-19-2019, 09:12 PM
RE: Stall's 16b cathedral - by Radioroslyn - 01-19-2019, 09:38 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-26-2019, 12:52 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-29-2019, 01:03 AM
RE: Stall's 16b cathedral - by rfeenstra - 01-29-2019, 01:18 AM
RE: Stall's 16b cathedral - by amptramp - 01-29-2019, 11:01 PM
RE: Stall's 16b cathedral - by Radioroslyn - 01-29-2019, 11:49 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 01-31-2019, 12:18 AM
RE: Stall's 16b cathedral - by Radioroslyn - 01-31-2019, 12:09 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 02-03-2019, 02:02 AM
RE: Stall's 16b cathedral - by Ron Ramirez - 02-03-2019, 09:09 AM
RE: Stall's 16b cathedral - by amptramp - 02-03-2019, 09:23 AM
RE: Stall's 16b cathedral - by morzh - 02-03-2019, 02:39 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 02-08-2019, 02:12 AM
RE: Stall's 16b cathedral - by Ron Ramirez - 02-08-2019, 10:25 AM
RE: Stall's 16b cathedral - by Ron Ramirez - 02-08-2019, 10:48 AM
RE: Stall's 16b cathedral - by mikethedruid - 02-08-2019, 01:33 PM
RE: Stall's 16b cathedral - by Ron Ramirez - 02-08-2019, 07:11 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 02-10-2019, 03:18 AM
RE: Stall's 16b cathedral - by jcassity - 02-10-2019, 07:52 AM
RE: Stall's 16b cathedral - by Ron Ramirez - 02-10-2019, 09:04 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 02-16-2019, 12:19 AM
RE: Stall's 16b cathedral - by mwoodruff - 02-22-2019, 12:46 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 02-22-2019, 05:45 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 02-28-2019, 09:57 PM
RE: Stall's 16b cathedral - by EdHolland - 02-28-2019, 10:15 PM
RE: Stall's 16b cathedral - by EdHolland - 03-01-2019, 07:13 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-02-2019, 08:18 PM
RE: Stall's 16b cathedral - by EdHolland - 03-03-2019, 02:57 PM
RE: Stall's 16b cathedral - by EdHolland - 03-03-2019, 05:43 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-04-2019, 11:43 PM
RE: Stall's 16b cathedral - by EdHolland - 03-05-2019, 01:53 AM
RE: Stall's 16b cathedral - by Radioroslyn - 03-05-2019, 02:20 PM
RE: Stall's 16b cathedral - by EdHolland - 03-06-2019, 12:40 AM
RE: Stall's 16b cathedral - by Radioroslyn - 03-06-2019, 01:01 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-07-2019, 10:49 PM
RE: Stall's 16b cathedral - by Radioroslyn - 03-07-2019, 11:53 PM
RE: Stall's 16b cathedral - by Ron Ramirez - 03-08-2019, 07:03 AM
RE: Stall's 16b cathedral - by morzh - 03-08-2019, 08:55 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-08-2019, 10:44 PM
RE: Stall's 16b cathedral - by Steve Davis - 03-12-2019, 02:47 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-12-2019, 05:42 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-14-2019, 01:53 AM
RE: Stall's 16b cathedral - by EdHolland - 03-14-2019, 04:00 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-14-2019, 11:24 PM
RE: Stall's 16b cathedral - by EdHolland - 03-14-2019, 11:44 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-16-2019, 03:12 PM
RE: Stall's 16b cathedral - by EdHolland - 03-16-2019, 10:16 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-16-2019, 11:48 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-18-2019, 12:37 AM
RE: Stall's 16b cathedral - by EdHolland - 03-18-2019, 10:41 AM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-28-2019, 06:42 PM
RE: Stall's 16b cathedral - by EdHolland - 03-28-2019, 08:13 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-28-2019, 10:53 PM
RE: Stall's 16b cathedral - by EdHolland - 03-28-2019, 11:30 PM
RE: Stall's 16b cathedral - by EdHolland - 03-29-2019, 01:17 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 03-29-2019, 11:40 PM
RE: Stall's 16b cathedral - by Stall-U-Rated - 04-23-2019, 07:07 PM
Users browsing this thread: 40 Guest(s)
91H Code 126 Restore
There are currently 4271 online users. [Complete List]
» 1 Member(s) | 4270 Guest(s)
