Another 89 Chasis from H**l!
#39
Connect an antenna and see if you can pull in any stations and don't worry just yet about dial calibration. If you do get something that will verify that the radio is somewhat working. If there is nothing then more work is needed.
Gregb
Another 89 Chasis from H**l! - by tkibler - 02-01-2019, 10:43 AM
RE: Another 89 Chasis from H**l! - by morzh - 02-01-2019, 10:59 AM
RE: Another 89 Chasis from H**l! - by tkibler - 02-01-2019, 11:41 AM
RE: Another 89 Chasis from H**l! - by Ron Ramirez - 02-01-2019, 01:13 PM
RE: Another 89 Chasis from H**l! - by tkibler - 02-01-2019, 02:02 PM
RE: Another 89 Chasis from H**l! - by Ron Ramirez - 02-01-2019, 02:15 PM
RE: Another 89 Chasis from H**l! - by simplex1040 - 02-04-2019, 10:52 PM
RE: Another 89 Chasis from H**l! - by tkibler - 02-05-2019, 09:01 AM
RE: Another 89 Chasis from H**l! - by tkibler - 02-05-2019, 09:04 AM
RE: Another 89 Chasis from H**l! - by Brad Winder - 02-05-2019, 12:25 PM
RE: Another 89 Chasis from H**l! - by tkibler - 02-05-2019, 09:44 PM
RE: Another 89 Chasis from H**l! - by morzh - 02-05-2019, 11:37 PM
RE: Another 89 Chasis from H**l! - by gregb - 02-05-2019, 11:51 PM
RE: Another 89 Chasis from H**l! - by tkibler - 02-06-2019, 09:56 AM
RE: Another 89 Chasis from H**l! - by tkibler - 02-08-2019, 08:23 AM
RE: Another 89 Chasis from H**l! - by PAradiogeek - 02-08-2019, 12:12 PM
RE: Another 89 Chasis from H**l! - by tkibler - 02-26-2019, 09:35 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-02-2019, 03:54 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-02-2019, 05:00 PM
RE: Another 89 Chasis from H**l! - by gregb - 03-02-2019, 06:06 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-02-2019, 07:22 PM
RE: Another 89 Chasis from H**l! - by gregb - 03-02-2019, 07:37 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-02-2019, 08:25 PM
RE: Another 89 Chasis from H**l! - by gregb - 03-02-2019, 09:29 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-02-2019, 11:14 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-03-2019, 10:31 PM
RE: Another 89 Chasis from H**l! - by Ron Ramirez - 03-03-2019, 10:33 PM
RE: Another 89 Chasis from H**l! - by gregb - 03-04-2019, 12:07 AM
RE: Another 89 Chasis from H**l! - by tkibler - 03-04-2019, 07:16 PM
RE: Another 89 Chasis from H**l! - by Ron Ramirez - 03-04-2019, 07:35 PM
RE: Another 89 Chasis from H**l! - by Radioroslyn - 03-04-2019, 08:09 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-05-2019, 03:31 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-05-2019, 03:34 PM
RE: Another 89 Chasis from H**l! - by gregb - 03-05-2019, 09:43 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-05-2019, 10:23 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-08-2019, 06:01 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-09-2019, 05:49 PM
RE: Another 89 Chasis from H**l! - by gregb - 03-09-2019, 06:10 PM
RE: Another 89 Chasis from H**l! - by Radioroslyn - 03-09-2019, 08:52 PM
RE: Another 89 Chasis from H**l! - by tkibler - 03-13-2019, 04:44 PM
91H Code 126 Restore
There are currently 4623 online users. [Complete List]
» 3 Member(s) | 4620 Guest(s)
