RCA V-210 field coil removal
Also (I have not pressed out any poles, but I think I say that) when pressing the pole out, the support should be applied against the part that is the coil holder, not against the outer rim of the basket, or it may warp.
RCA V-210 field coil removal - by Steve D - 03-05-2019, 05:07 PM
RE: RCA V-210 field coil removal - by Steve Davis - 03-05-2019, 05:44 PM
RE: RCA V-210 field coil removal - by Steve D - 03-08-2019, 05:15 PM
RE: RCA V-210 field coil removal - by Arran - 03-09-2019, 06:11 AM
RE: RCA V-210 field coil removal - by tbone - 03-09-2019, 10:24 AM
RE: RCA V-210 field coil removal - by morzh - 03-09-2019, 11:54 AM
RE: RCA V-210 field coil removal - by tbone - 03-09-2019, 01:48 PM
RE: RCA V-210 field coil removal - by Steve D - 03-10-2019, 12:52 PM
RE: RCA V-210 field coil removal - by Arran - 03-11-2019, 05:41 AM
RE: RCA V-210 field coil removal - by sdradioman - 03-11-2019, 07:17 AM
RE: RCA V-210 field coil removal - by Phlogiston - 03-11-2019, 11:36 AM
RE: RCA V-210 field coil removal - by morzh - 03-11-2019, 11:49 AM
RE: RCA V-210 field coil removal - by Steve D - 03-19-2019, 04:08 PM
RE: RCA V-210 field coil removal - by Steve D - 03-19-2019, 04:13 PM
RE: RCA V-210 field coil removal - by EdHolland - 03-19-2019, 09:29 PM
RE: RCA V-210 field coil removal - by Steve D - 03-21-2019, 09:09 AM
RE: RCA V-210 field coil removal - by Phlogiston - 03-21-2019, 11:38 AM
RE: RCA V-210 field coil removal - by Steve D - 03-23-2019, 05:46 PM
RE: RCA V-210 field coil removal - by klondike98 - 03-24-2019, 10:43 PM
RE: RCA V-210 field coil removal - by Steve D - 04-08-2019, 01:34 PM
RE: RCA V-210 field coil removal - by Steve D - 04-08-2019, 01:37 PM
RE: RCA V-210 field coil removal - by Steve D - 04-29-2019, 04:34 PM
RE: RCA V-210 field coil removal - by Steve D - 04-29-2019, 04:36 PM
RE: RCA V-210 field coil removal - by Steve D - 05-06-2019, 10:48 AM
RE: RCA V-210 field coil removal - by Steve D - 05-06-2019, 10:50 AM
RE: RCA V-210 field coil removal - by morzh - 05-06-2019, 11:19 AM
RE: RCA V-210 field coil removal - by sdradioman - 05-06-2019, 01:53 PM
RE: RCA V-210 field coil removal - by Steve D - 05-16-2019, 11:23 AM
