Low voltage and oscillation
I don't know about the transformer Morzh cause this chassis looked pretty unmolested.  The Ecaps even still had a lot of liquid in them.  But I will check the voltage again tomorrow with a VTVM and see  if that makes a difference.  It just seems strange to see a shortage of 35 to 40 volts all the way thru the set and keep that consistency all thru the set too.
Thanks for the reply
Dick
Low voltage and oscillation - by madsowry - 03-11-2019, 07:01 PM
RE: Low voltage and oscillation - by morzh - 03-11-2019, 08:52 PM
RE: Low voltage and oscillation - by madsowry - 03-11-2019, 10:42 PM
RE: Low voltage and oscillation - by Chas - 03-12-2019, 11:58 AM
RE: Low voltage and oscillation - by madsowry - 03-12-2019, 05:26 PM
RE: Low voltage and oscillation - by Chas - 03-12-2019, 06:08 PM
RE: Low voltage and oscillation - by madsowry - 03-12-2019, 11:14 PM
91H Code 126 Restore
There are currently 4580 online users. [Complete List]
» 2 Member(s) | 4578 Guest(s)
