Another Alignment Tool
The steel tip is about 1/8 x 1/4 with a small spike just over 1/16 wide and about 3/8 long. The tip is small enough that I can't imagine it having much effect on the tuning. It certainly would have less effect than using an ordinary screw driver. I'm away from my shop right now, but the first of the week, I will post some photos.
M R Radios   C M Tubes
Another Alignment Tool - by Steve Davis - 03-12-2019, 02:42 PM
RE: Another Alignment Tool - by Stall-U-Rated - 03-12-2019, 06:11 PM
RE: Another Alignment Tool - by OldRestorer - 03-13-2019, 01:01 PM
RE: Another Alignment Tool - by Phlogiston - 03-13-2019, 01:04 PM
RE: Another Alignment Tool - by mark123 - 03-13-2019, 02:11 PM
RE: Another Alignment Tool - by Steve Davis - 03-13-2019, 02:21 PM
RE: Another Alignment Tool - by Steve Davis - 03-14-2019, 12:37 PM
RE: Another Alignment Tool - by morzh - 03-14-2019, 01:28 PM
RE: Another Alignment Tool - by Phlogiston - 03-14-2019, 01:35 PM
RE: Another Alignment Tool - by Steve Davis - 03-15-2019, 07:09 PM
RE: Another Alignment Tool - by Greggshere - 03-16-2019, 01:07 PM
RE: Another Alignment Tool - by Ron Ramirez - 03-16-2019, 01:22 PM
RE: Another Alignment Tool - by Greggshere - 03-16-2019, 02:41 PM
RE: Another Alignment Tool - by Steve Davis - 03-18-2019, 02:40 PM
RE: Another Alignment Tool - by Greggshere - 03-28-2019, 03:00 PM
RE: Another Alignment Tool - by TV MAN - 03-28-2019, 04:11 PM
RE: Another Alignment Tool - by mikethedruid - 03-28-2019, 05:48 PM
RE: Another Alignment Tool - by Phlogiston - 03-28-2019, 09:38 PM
There are currently 9784 online users. [Complete List]
» 2 Member(s) | 9782 Guest(s)
