Repair IF transformer in 39-6
If you only broke off one of the leads to the coil, it is quite possible to very carefully, with a good magnifying device, find the broken end of the wire in the coil. I've done it before using a jeweler's loupe and a dental probe. Then you may be able to unwind just enough of the wire to reach a connection point or connect to a new lead. Twist the tiny wire around the connection point and heat with a very hot soldering iron, then apply solder. If the soldering iron is sufficiently hot, it will melt off the insulation; trying to scrape it off is very difficult. If you only unwind an inch or two, the change in inductance and resistance will not be problematic.
Repair IF transformer in 39-6 - by Jake Blake - 02-08-2019, 02:29 PM
RE: Repair IF transformer in 39-6 - by morzh - 02-08-2019, 02:37 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 02-08-2019, 03:34 PM
RE: Repair IF transformer in 39-6 - by morzh - 02-08-2019, 11:29 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 02-09-2019, 12:12 AM
RE: Repair IF transformer in 39-6 - by Jake Blake - 03-09-2019, 10:04 AM
RE: Repair IF transformer in 39-6 - by morzh - 03-09-2019, 11:21 AM
RE: Repair IF transformer in 39-6 - by Jake Blake - 03-14-2019, 07:46 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 03-14-2019, 07:49 PM
RE: Repair IF transformer in 39-6 - by morzh - 03-14-2019, 08:23 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 03-14-2019, 10:32 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 03-14-2019, 10:34 PM
RE: Repair IF transformer in 39-6 - by morzh - 03-15-2019, 08:31 AM
RE: Repair IF transformer in 39-6 - by morzh - 03-15-2019, 01:41 PM
RE: Repair IF transformer in 39-6 - by Stonewall - 03-16-2019, 04:41 PM
RE: Repair IF transformer in 39-6 - by rfeenstra - 03-16-2019, 07:23 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 03-17-2019, 01:15 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 03-17-2019, 01:30 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 03-17-2019, 11:12 PM
RE: Repair IF transformer in 39-6 - by morzh - 03-18-2019, 08:27 AM
RE: Repair IF transformer in 39-6 - by Jake Blake - 04-16-2019, 04:08 PM
RE: Repair IF transformer in 39-6 - by morzh - 04-17-2019, 01:39 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 04-18-2019, 02:06 PM
RE: Repair IF transformer in 39-6 - by morzh - 04-18-2019, 02:18 PM
RE: Repair IF transformer in 39-6 - by Jake Blake - 04-18-2019, 02:29 PM
91H Code 126 Restore
There are currently 4410 online users. [Complete List]
» 1 Member(s) | 4409 Guest(s)
