phonograph in 47-1227 Philco console
I think the answer to your problem might be found here:
Expired link deleted by site admin.
Something is wrong with your changer, as it sounds like it is stuck in "reject" mode. Unfortunately, I never learned much about changers, so I can't help you here. Music in a Bottle's radio-phonograph (see link above) is advertised as having a working phono, so you might be better off getting a working unit than spending a lot of time with a non-working one. Just a thought.
EDIT: Oops, Terry beat me to it. If you feel comfortable working on the changer you have, I would follow his suggestions. Otherwise, follow the link I posted above and ask Music about his changer.
Re: phonograph in 47-1227 Philco console - by Ron Ramirez - 11-14-2010, 06:50 PM
The speaker table error?
Philco 70 antenna lead
