46-1226 factory finish ?? satin of gloss
i have a 46-1226 code 122 it has a satin finish do you know what was stock finish thanks....john
46-1226 factory finish ?? satin of gloss - by jstaf40 - 11-14-2010, 07:33 PM
There are currently 9228 online users. [Complete List]
» 3 Member(s) | 9225 Guest(s)
