Threads: 44
City: Menlo Park
State, Province, Country: CA
Hmm, somehow, this seems familiar from my recent Zenith project. It had obviously been kept all together since new, including odd bits and pieces, user manual, promotional literature for the FM system etc. It came with cardboard pieces like this, marked "Remove before use" or similar wording. I wonder if yours are similar transport packing/protection pieces?
RE: Another 7G605 Zenith TO - by EdHolland - 03-18-2019, 10:52 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
