Restored Philco 46-420 code 121 has slight low pitch hum.
Well the thing is I swapped out multiples of ALL the tubes, replaced all the resistors and capacitors so even if I found a unacceptable voltage what would cause it?
Also what would fix it?
I put in another 20 mf electrolytic with + end on pin 4 of 50L6 and - end on B- and I still get a low hum.
I have another speaker/transformer assembly from a different Hippo project and it is an exact match.
I suppose I could install it to see if that helps...
RE: Restored Philco 46-420 code 121 has slight low pitch hum. - by terrylett - 03-19-2019, 11:43 AM
91H Code 126 Restore
There are currently 3975 online users. [Complete List]
» 1 Member(s) | 3974 Guest(s)
