phonograph in 47-1227 Philco console
If you want to play 33-1/3 and 45 rpm records, keep your eyes peeled for a 1949 Philco changer with two tone arms (one for LP, the other for 78), or an early 1950s three-speed model from a Philco. One of these will be more likely to fit the cutout in your set's motor board than will a newer changer, which will be physically smaller than the original changer.
Re: phonograph in 47-1227 Philco console - by Ron Ramirez - 11-14-2010, 07:45 PM
The speaker table error?
Philco 70 antenna lead
