Alignment Questions.
I have a Silvertone 101.571 chassis 6321 the Schematic here.
http://www.nostalgiaair.org/pagesbymodel...017485.pdf
The problem is I don't have any alignment info, other than a remark that " Conventional Alignment See Special Section Volume VIII". Which I can not find anywhere. I finished the recap someone started, replaced all resistors that were over 20%. I replaced the 6K8 which was bad the others tested good. Volume and output sounds good and I pick up some stuff on the SW band but nothing on BC. T1 and T2  IF coils are good. I have put 455kc signal in the 6K8  pin 3 and do get a tone so I did adjust the IF for output and they do peak out but not sure where to go next. It says to adj C5 1550kc and C 1 1400kc Any help would be appreciated.
Eric
Alignment Questions. - by Eric - 03-19-2019, 05:05 PM
RE: Alignment Questions. - by Chas - 03-19-2019, 05:18 PM
RE: Alignment Questions. - by Eric - 03-20-2019, 09:36 AM
RE: Alignment Questions. - by Chas - 03-20-2019, 11:03 AM
RE: Alignment Questions. - by radio63 - 03-20-2019, 03:13 PM
RE: Alignment Questions. - by Eric - 03-21-2019, 10:42 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2517 online users. [Complete List]
» 1 Member(s) | 2516 Guest(s)
