42-395....am I missing something?
Yep. Its the button on the left.
I picked this up as a "plays fine" radio. The guy had it playing in his garage. It sounds pretty decent. I was more impressed with the condition of the cabinet. No issues in the wood, and the escutcheon has minimal shrinkage, and just a bit of a ripple in it.
I'm not normally attracted to the push button consoles, but for some reason I like this one.
I see Loktal tubes. is that a bad thing?
42-395....am I missing something? - by rdnzl - 03-19-2019, 09:50 PM
RE: 42-395....am I missing something? - by morzh - 03-19-2019, 09:57 PM
RE: 42-395....am I missing something? - by KCMike - 03-19-2019, 10:05 PM
RE: 42-395....am I missing something? - by morzh - 03-20-2019, 08:31 AM
RE: 42-395....am I missing something? - by rdnzl - 03-20-2019, 11:36 AM
RE: 42-395....am I missing something? - by rdnzl - 03-20-2019, 01:40 PM
RE: 42-395....am I missing something? - by Arran - 03-20-2019, 05:09 PM
RE: 42-395....am I missing something? - by rdnzl - 03-20-2019, 05:39 PM
RE: 42-395....am I missing something? - by rdnzl - 03-20-2019, 09:14 PM
