phonograph in 47-1227 Philco console
keith49vj3 Wrote:Does anyone know if there are any websites where I can download a free strobe disc image for checking the motor speed under a fluorescent light?
Try one of these links:
http://www.vinylengine.com/strobe-discs.shtml
http://www.quadesl.com/pdf/strobe.pdf
You probably know this already, but you want a 60 Hz disc.
Re: phonograph in 47-1227 Philco console - by Ron Ramirez - 11-15-2010, 09:26 AM
The speaker table error?
Philco 70 antenna lead
