Philco 32-8248 power transformer
Hello,
I just found this thread and am curious if you still have this power transformer?   It is the exact transformer I am needing for my Philco 46-1226.   If it is still available, would you be willing to sell it?  Thanks!
~Jon~
Philco 32-8248 power transformer - by Marko - 11-10-2018, 08:32 AM
RE: Philco 32-8248 power transformer - by KCMike - 11-10-2018, 10:31 AM
RE: Philco 32-8248 power transformer - by Marko - 11-10-2018, 10:49 AM
RE: Philco 32-8248 power transformer - by morzh - 11-10-2018, 11:27 AM
RE: Philco 32-8248 power transformer - by Marko - 11-10-2018, 08:17 PM
RE: Philco 32-8248 power transformer - by morzh - 11-10-2018, 09:51 PM
RE: Philco 32-8248 power transformer - by Philcokid - 03-26-2019, 11:44 AM
RE: Philco 32-8248 power transformer - by Marko - 03-26-2019, 12:35 PM
Philco 91 Tuning Condenser
There are currently 8974 online users. [Complete List]
» 3 Member(s) | 8971 Guest(s)
