Another Alignment Tool
I made the tool I use from a piece of 1/16 inch brass rod. Cut it about 6 inches long, bent over one end about 1 inch from the end to make a handle, ground the other end to a screwdriver point. To insulate just used heat shrink a little above the end, wrapped the handle end with black plastic electrical tape. It's non-magnetic and works great.
Another Alignment Tool - by Steve Davis - 03-12-2019, 02:42 PM
RE: Another Alignment Tool - by Stall-U-Rated - 03-12-2019, 06:11 PM
RE: Another Alignment Tool - by OldRestorer - 03-13-2019, 01:01 PM
RE: Another Alignment Tool - by Phlogiston - 03-13-2019, 01:04 PM
RE: Another Alignment Tool - by mark123 - 03-13-2019, 02:11 PM
RE: Another Alignment Tool - by Steve Davis - 03-13-2019, 02:21 PM
RE: Another Alignment Tool - by Steve Davis - 03-14-2019, 12:37 PM
RE: Another Alignment Tool - by morzh - 03-14-2019, 01:28 PM
RE: Another Alignment Tool - by Phlogiston - 03-14-2019, 01:35 PM
RE: Another Alignment Tool - by Steve Davis - 03-15-2019, 07:09 PM
RE: Another Alignment Tool - by Greggshere - 03-16-2019, 01:07 PM
RE: Another Alignment Tool - by Ron Ramirez - 03-16-2019, 01:22 PM
RE: Another Alignment Tool - by Greggshere - 03-16-2019, 02:41 PM
RE: Another Alignment Tool - by Steve Davis - 03-18-2019, 02:40 PM
RE: Another Alignment Tool - by Greggshere - 03-28-2019, 03:00 PM
RE: Another Alignment Tool - by TV MAN - 03-28-2019, 04:11 PM
RE: Another Alignment Tool - by mikethedruid - 03-28-2019, 05:48 PM
RE: Another Alignment Tool - by Phlogiston - 03-28-2019, 09:38 PM
There are currently 10807 online users. [Complete List]
» 2 Member(s) | 10805 Guest(s)
