Grundig 3068 Hi-Fi Zauberklang
I found this today for cheap.  Everything works, except the EM34 tuning eye tube.  It's been playing in a guy's garage for years. He purchased it in Germany in the 1950's.
I'm always amazed when I see these radios....they are huge.  It sounds great, and the tuner is very sensitive. The cabinet is very clean, as is the dial. There just a small bit of laminate separation at the bottom of one side, that I will be gluing down.
My first old German radio.
A bunch of odd looking jacks in the back. Can any of these be used to plug in an MP3 player or Bluetooth receiver?  what sort of plugs would it take?
Is there a manual in ENGLISH for these?
Thanks
[Image: https://i.imgur.com/x9r3Mxa.jpg?1]
Grundig 3068 Hi-Fi Zauberklang - by rdnzl - 03-29-2019, 05:32 PM
RE: Grundig 3068 Hi-Fi Zauberklang - by rdnzl - 03-29-2019, 06:01 PM
RE: Grundig 3068 Hi-Fi Zauberklang - by rdnzl - 03-29-2019, 07:11 PM
RE: Grundig 3068 Hi-Fi Zauberklang - by EdHolland - 03-29-2019, 07:44 PM
RE: Grundig 3068 Hi-Fi Zauberklang - by rdnzl - 03-29-2019, 08:11 PM
There are currently 6120 online users. [Complete List]
» 1 Member(s) | 6119 Guest(s)
