Grundig 3068 Hi-Fi Zauberklang
I don't see a 5 pin DIN socket. Here is whats back there:
[Image: https://i.imgur.com/4dJCwXj.jpg?1]
[Image: https://i.imgur.com/0CBbZNy.jpg]
Grundig 3068 Hi-Fi Zauberklang - by rdnzl - 03-29-2019, 05:32 PM
RE: Grundig 3068 Hi-Fi Zauberklang - by rdnzl - 03-29-2019, 06:01 PM
RE: Grundig 3068 Hi-Fi Zauberklang - by rdnzl - 03-29-2019, 07:11 PM
RE: Grundig 3068 Hi-Fi Zauberklang - by EdHolland - 03-29-2019, 07:44 PM
RE: Grundig 3068 Hi-Fi Zauberklang - by rdnzl - 03-29-2019, 08:11 PM
There are currently 3133 online users. [Complete List]
» 1 Member(s) | 3132 Guest(s)
