46-1226 code 122 burnt resistor help
You may be looking at RF bypass cap. They are sometimes used on the filaments to prevent stray coupling between stages. A 0.01 uF 630V cap should work. Richard
46-1226 code 122 burnt resistor help - by jstaf40 - 11-15-2010, 09:11 PM
Re: 46-1226 code 122 burnt resistor help - by rghines1 - 11-16-2010, 08:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
