RCA T64 tuning dial indicator problem
        Hello All, working on my RCA T64 and have a question. Before pulling the chassis, the dial indicator moved with the tuning knob. I pulled the chassis and cannot find anyway that the dial string attached to the indicator mechanism. I didn't  see or find any kind of a part but after reinstalling the chassis the indicator no longer moves with the tuning knob!
   The attached photo shows two holes with green arrows where I think something might mount to or possibly the slot where the yellow arrow is? Anyone ever work on one of these? Thanks
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
RCA T64 tuning dial indicator problem - by 462ron - 03-30-2019, 09:45 AM
