RCA T64 tuning dial indicator problem
Here is another one with more about the dial stringing.
https://www.youtube.com/watch?v=1ve5MUJiA0c
Dan in Calgary
   Living in Calgary Alberta
RCA T64 tuning dial indicator problem - by 462ron - 03-30-2019, 09:45 AM
RE: RCA T64 tuning dial indicator problem - by Dan Walker - 03-31-2019, 10:52 AM
