Philco Model 90 Tuning Dial
Hi Terry . Sorry for the late reply. The radio is put back together. I can tune the radio if I push down on the tuning knob as I turn the tuning knob. I have two model 90's with the same problem. One is worse than the other however. It is irritating indeed. The restore turned out excellent however. Could you send me a private message so I can send you my contact information?
RE: Philco Model 90 Tuning Dial - by Radioroslyn - 04-05-2019, 11:09 PM
RE: Philco Model 90 Tuning Dial - by Jonathan Philco 41 - 04-09-2019, 06:41 PM
There are currently 10243 online users. [Complete List]
» 1 Member(s) | 10242 Guest(s)
