Scott Marine Radio
Going from my aging memory, I seem to recall that one of the filter cans in my SLR-H was an oil filled unit rated at 500V or more. If a 450V electrolytic is used here it will leak until it pops as will a tacked-on replacement. I do not know what the oil is in these caps - be careful.
https://www.russoldradios.com/blog/40-old-radios
At the bottom of the post.
Russ
Scott Marine Radio - by rfeenstra - 04-01-2019, 11:32 PM
RE: Scott Marine Radio - by rfeenstra - 04-05-2019, 12:19 AM
RE: Scott Marine Radio - by Eliot Ness - 04-05-2019, 08:16 AM
RE: Scott Marine Radio - by Ron Ramirez - 04-05-2019, 08:20 AM
RE: Scott Marine Radio - by rfeenstra - 04-05-2019, 10:54 AM
RE: Scott Marine Radio - by rfeenstra - 04-10-2019, 12:52 AM
RE: Scott Marine Radio - by Phlogiston - 04-10-2019, 01:30 PM
RE: Scott Marine Radio - by rfeenstra - 04-10-2019, 08:54 PM
RE: Scott Marine Radio - by rfeenstra - 04-11-2019, 06:43 PM
RE: Scott Marine Radio - by rfeenstra - 06-20-2019, 02:50 PM
RE: Scott Marine Radio - by Eliot Ness - 06-20-2019, 03:42 PM
RE: Scott Marine Radio - by Ron Ramirez - 06-20-2019, 07:50 PM
There are currently 10210 online users. [Complete List]
» 1 Member(s) | 10209 Guest(s)
