Are these capacitors?
Ok, but what is the crusty coating on the center one?
Others have tar like covering on them and one has friction tape wrapped around it.
There are several of these critters under this chassis.
Murf
Are these capacitors? - by murf - 04-10-2019, 06:03 PM
RE: Are these capacitors? - by Radioroslyn - 04-10-2019, 06:19 PM
RE: Are these capacitors? - by vinzer - 04-10-2019, 07:52 PM
RE: Are these capacitors? - by murf - 04-10-2019, 09:29 PM
RE: Are these capacitors? - by murf - 04-11-2019, 08:30 AM
RE: Are these capacitors? - by jcassity - 04-16-2019, 10:12 AM
RE: Are these capacitors? - by morzh - 04-16-2019, 11:47 AM
RE: Are these capacitors? - by murf - 04-27-2019, 08:34 AM
There are currently 10428 online users. [Complete List]
» 1 Member(s) | 10427 Guest(s)
