Can you identify?
Buy 'em when you see them and you can always fix them later... You may never see that radio again... Always buy them when you see them if the condition and price are right... It may be your only chance... We know we can get parts, tubes, caps, cloth, knobs, etc. to get them going, but you have to get the radio first...
Can you identify? - by rfeenstra - 04-11-2019, 10:03 AM
RE: Can you identify? - by Jake Blake - 04-11-2019, 10:06 AM
RE: Can you identify? - by KCMike - 04-11-2019, 11:10 AM
RE: Can you identify? - by morzh - 04-11-2019, 11:24 AM
RE: Can you identify? - by rfeenstra - 04-11-2019, 11:28 AM
RE: Can you identify? - by morzh - 04-11-2019, 11:38 AM
RE: Can you identify? - by KCMike - 04-11-2019, 12:52 PM
RE: Can you identify? - by sdradioman - 04-11-2019, 01:45 PM
RE: Can you identify? - by rfeenstra - 04-11-2019, 02:59 PM
RE: Can you identify? - by sdradioman - 04-11-2019, 04:00 PM
RE: Can you identify? - by gregb - 04-11-2019, 07:55 PM
RE: Can you identify? - by rfeenstra - 04-11-2019, 08:27 PM
