Can you identify?
I have two of them not in the best condition free for the taking if you happen to be passing through central Alberta Canada.
Gregb
Can you identify? - by rfeenstra - 04-11-2019, 10:03 AM
RE: Can you identify? - by Jake Blake - 04-11-2019, 10:06 AM
RE: Can you identify? - by KCMike - 04-11-2019, 11:10 AM
RE: Can you identify? - by morzh - 04-11-2019, 11:24 AM
RE: Can you identify? - by rfeenstra - 04-11-2019, 11:28 AM
RE: Can you identify? - by morzh - 04-11-2019, 11:38 AM
RE: Can you identify? - by KCMike - 04-11-2019, 12:52 PM
RE: Can you identify? - by sdradioman - 04-11-2019, 01:45 PM
RE: Can you identify? - by rfeenstra - 04-11-2019, 02:59 PM
RE: Can you identify? - by sdradioman - 04-11-2019, 04:00 PM
RE: Can you identify? - by gregb - 04-11-2019, 07:55 PM
RE: Can you identify? - by rfeenstra - 04-11-2019, 08:27 PM
