Question about A Philco 43-1201
The samp ends too sharply to have been a 8(especially at top & center), we'll just have to agree to disagree.
Maybe someone at Philco was pulling a prank?
Tom
Question about A Philco 43-1201 - by Jamesscott - 04-11-2019, 12:37 AM
RE: Question about A Philco 43-1201 - by Patrick - 04-11-2019, 06:27 AM
RE: Question about A Philco 43-1201 - by Patrick - 04-11-2019, 09:20 PM
RE: Question about A Philco 43-1201 - by Patrick - 04-12-2019, 05:59 AM
RE: Question about A Philco 43-1201 - by 35Z5 - 04-12-2019, 09:19 AM
RE: Question about A Philco 43-1201 - by 35Z5 - 04-12-2019, 09:47 AM
There are currently 11391 online users. [Complete List]
» 2 Member(s) | 11389 Guest(s)
