Philco 514 Questions
Thank you Ron. I figured it was here somewhere, just have to use the right keyword ("alignment" doesn't work). Your set of instructions are much better than the basic ones I found elsewhere.
So, I have had a change in direction on the speaker. Instead of the re-cone job the owner has decided to go with a PM speaker mounted in place of the cone. I have located an 8 ohm, 8 inch, full range driver to connect to an output transformer. To check this configuration, I used my test speaker connected to a universal OT and tested the output of each of the 6 transformer speaker lugs. The output is now so loud I can't turn it down with the volume control. The set also oscillates at various positions of the dial. I'm thinking there's too much gain and maybe reducing the B+ might fix that. The 10K volume pot. also might be a problem. More testing to resume.
Philco 514 Questions - by RodB - 01-12-2019, 02:42 PM
RE: Philco 514 Questions - by RodB - 01-12-2019, 04:53 PM
RE: Philco 514 Questions - by Greggshere - 01-12-2019, 06:01 PM
RE: Philco 514 Questions - by Arran - 01-13-2019, 03:02 AM
RE: Philco 514 Questions - by RodB - 01-13-2019, 03:50 PM
RE: Philco 514 Questions - by RodB - 01-16-2019, 11:32 AM
RE: Philco 514 Questions - by morzh - 01-16-2019, 11:52 AM
RE: Philco 514 Questions - by RodB - 01-23-2019, 02:08 PM
RE: Philco 514 Questions - by RodB - 01-26-2019, 06:09 PM
RE: Philco 514 Questions - by Radioroslyn - 01-26-2019, 07:24 PM
RE: Philco 514 Questions - by RodB - 01-27-2019, 08:12 PM
RE: Philco 514 Questions - by RodB - 02-10-2019, 04:23 PM
RE: Philco 514 Questions - by Arran - 02-10-2019, 05:08 PM
RE: Philco 514 Questions - by RodB - 03-11-2019, 01:48 PM
RE: Philco 514 Questions - by RodB - 04-05-2019, 08:49 PM
RE: Philco 514 Questions - by Ron Ramirez - 04-05-2019, 09:32 PM
RE: Philco 514 Questions - by RodB - 04-12-2019, 01:42 PM
RE: Philco 514 Questions - by morzh - 04-12-2019, 02:10 PM
RE: Philco 514 Questions - by RodB - 04-15-2019, 01:25 PM
RE: Philco 514 Questions - by Radioroslyn - 04-15-2019, 08:20 PM
91H Code 126 Restore
There are currently 4006 online users. [Complete List]
» 3 Member(s) | 4003 Guest(s)
