Characteristics and components of vacuum tubes
Hi Ron,
Thanks for the reply and info. Per your suggestion, I will contact Alan Douglas for his advice. Your help, concern and endeavors are much appreciated.
Floyd
Re: Characteristics and components of vacuum tubes - by Radionut78 - 11-21-2010, 10:45 PM
Eico 232 VTVM Schematic
There are currently 6492 online users. [Complete List]
» 1 Member(s) | 6491 Guest(s)
