Are these capacitors?
and ... to the opposite end of the rainbow....
the object i am pointing to here *******IS NOT*********** a capacitor..
which kinda blind sided me because this is the first time i ran into these which are resistors.
Are these capacitors? - by murf - 04-10-2019, 06:03 PM
RE: Are these capacitors? - by Radioroslyn - 04-10-2019, 06:19 PM
RE: Are these capacitors? - by vinzer - 04-10-2019, 07:52 PM
RE: Are these capacitors? - by murf - 04-10-2019, 09:29 PM
RE: Are these capacitors? - by murf - 04-11-2019, 08:30 AM
RE: Are these capacitors? - by jcassity - 04-16-2019, 10:12 AM
RE: Are these capacitors? - by morzh - 04-16-2019, 11:47 AM
RE: Are these capacitors? - by murf - 04-27-2019, 08:34 AM
There are currently 11062 online users. [Complete List]
» 2 Member(s) | 11060 Guest(s)
