Are these capacitors?
Yes. Those are wire-wounds. Used quite a bit, in Philcos, in Zenith TOs. Probably in other places too.
Are these capacitors? - by murf - 04-10-2019, 06:03 PM
RE: Are these capacitors? - by Radioroslyn - 04-10-2019, 06:19 PM
RE: Are these capacitors? - by vinzer - 04-10-2019, 07:52 PM
RE: Are these capacitors? - by murf - 04-10-2019, 09:29 PM
RE: Are these capacitors? - by murf - 04-11-2019, 08:30 AM
RE: Are these capacitors? - by jcassity - 04-16-2019, 10:12 AM
RE: Are these capacitors? - by morzh - 04-16-2019, 11:47 AM
RE: Are these capacitors? - by murf - 04-27-2019, 08:34 AM
There are currently 10234 online users. [Complete List]
» 1 Member(s) | 10233 Guest(s)
