Philco 87 grid voltages
Good morning,
I'm new to the Phorum but expect to visit often, hopefully more to improve my knowledge than plea for help.
I completed the electronic restoration of a model 87 and it plays wonderfully.  The only thing that has me scratching my head are the grid voltages on the #26 RF tubes and the 45 output tubes.  Rider's calls for 6 volts on the RF tube grids and 45 on the 45 tube grids. I believe they are all mislabeled as positive rather than negative voltages but that's not the issue. My issue is that I measure 0 volts on all the grids.  I'm measuring from chassis ground. The plate voltages are within range of the schematic.
The radio performs perfectly so I don't think I have a problem but why am I not getting negative voltages at the grids?  The only issue this radio had was an open field coil which I had rewound by the gentlemen at the Alabama Historical Radio Society. They do great work. Oh, it also had sprung tuning cables. That was a joy to fix. Finally decided to give up on the cables and use fishing leaders.
Thanks in advance for any help on my voltage conundrum.
Scott
Philco 87 grid voltages - by HooiserScootrer - 04-17-2019, 08:06 AM
RE: Philco 87 grid voltages - by rfeenstra - 04-17-2019, 10:08 AM
RE: Philco 87 grid voltages - by Radioroslyn - 04-17-2019, 10:39 AM
RE: Philco 87 grid voltages - by HooiserScootrer - 04-17-2019, 08:02 PM
91H Code 126 Restore
There are currently 4774 online users. [Complete List]
» 2 Member(s) | 4772 Guest(s)
