Help Me Identify My Sister's Radio
Does it look like http://www.philcoradio.com/gallery/1938a.htm#u ? If so, it is a 38-15 from 1938.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Help Me Identify My Sister's Radio - by Guest - 02-14-2006, 03:49 PM
[No subject] - by Terry Judkins - 02-14-2006, 10:04 PM
[No subject] - by Guest - 02-14-2006, 10:36 PM
There are currently 10581 online users. [Complete List]
» 1 Member(s) | 10580 Guest(s)
