Philco 21
So, here are some pictures.....
I need one small knob
The front is bowed out a little
Here's the underside
will post more of the backside when I get the chance...
Philco 21 - by Simon Wa3uay - 04-17-2019, 03:44 PM
RE: Philco 21 - by Radioroslyn - 04-17-2019, 04:04 PM
RE: Philco 21 - by Simon Wa3uay - 04-18-2019, 03:21 PM
RE: Philco 21 - by Radioroslyn - 04-18-2019, 05:13 PM
RE: Philco 21 - by GarySP - 04-19-2019, 11:50 AM
RE: Philco 21 - by Simon Wa3uay - 04-19-2019, 02:25 PM
RE: Philco 21 - by Simon Wa3uay - 04-19-2019, 02:28 PM
RE: Philco 21 - by morzh - 04-19-2019, 06:25 PM
There are currently 10802 online users. [Complete List]
» 2 Member(s) | 10800 Guest(s)
